Gre Tunnel Output drops
Shajil Melethil
Dear All,
I have seen an error in GRE configured between two routers over WAN.  i am monitoring the WAN link and GRe tunnel via WhatsupGold NMS and it reported that Gre tunnel having packet loss sometimes and this time it affects the services and traffic passing over tunnel.
sh int t101 shows output drops . is that the problem ? i have read that i have to adjust MTC size but i tried to change the tunnel MTU to 1400 but still sh int t101 shows MTU as 1514 ? What could be the problem of output drops in my tunnel link. this is only error i am seeing .
SiteA #sh int t101
Tunnel101 is up, line protocol is up
  Hardware is Tunnel
  Description:   Internet address is 172.18.1.1/30
  MTU 1514 bytes, BW 2048 Kbit/sec, DLY 500000 usec,
     reliability 255/255, txload 1/255, rxload 5/255
  Encapsulation TUNNEL, loopback not set
  Keepalive set (60 sec), retries 2
  Tunnel source 172.16.172.82, destination 172.31.186.254
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w4d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 179
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 48000 bits/sec, 13 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     11172631 packets input, 2233002357 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1663202 packets output, 148126571 bytes, 0 underruns
SiteB#sh int t101
  Hardware is Tunnel
  Description:   Internet address is 172.18.1.2/30
     reliability 255/255, txload 5/255, rxload 1/255
  Tunnel source 172.31.186.254, destination 172.16.172.82
  Tunnel TTL 255
  Last input 00:00:02, output 00:00:02, output hang never
  Last clearing of "show interface" counters 7w6d
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 46000 bits/sec, 19 packets/sec
     31399204 packets input, 2675546039 bytes, 0 no buffer
     347796910 packets output, 1364546113 bytes, 0 underruns
Leo Laohoo
Duplicate post #1.
jayeshtjayaraj
Check the communication between soruce and destionation. May be issue in your wan link.
