GUI access to Nexus 3548
Guys I need to enable GUI access to my nexus switch. Is there any commands to enable http, i cant able to access by http://ip-of-nexus.
The version is
system image file is:    bootflash:/n3500-uk9.5.0.3.A1.1.bin
and
NExus-EDC-N3K-S2# sh feature
Feature Name          Instance  State
bfd                   1         disabled
bfd_app               1         disabled
bgp                   1         disabled
dhcp                  1         disabled
eigrp                 1         disabled
eigrp                 2         disabled
eigrp                 3         disabled
eigrp                 4         disabled
hsrp_engine           1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
ldap                  1         disabled
msdp                  1         disabled
nat                   1         disabled
ospf                  1         disabled
ospf                  2         disabled
ospf                  3         disabled
ospf                  4         disabled
ospfv3                1         disabled
ospfv3                2         disabled
ospfv3                3         disabled
ospfv3                4         disabled
pim                   1         disabled
poe                   1         disabled
private-vlan          1         disabled
privilege             1         disabled
ptp                   1         disabled
rip                   1         disabled
rip                   2         disabled
rip                   3         disabled
rip                   4         disabled
scheduler             1         disabled
scpServer             1         disabled
sflow                 1         disabled
sshServer             1         enabled
tacacs                1         disabled
telnetServer          1         enabled
tunnel                1         disabled
udld                  1         disabled
vpc                   1         disabled
vrrp                  1         disabled
vtp                   1         disabled
Nexus-EDC-N3K-S2#
It doesnt show http, Does that mean it doesnt have http feauture? Request your assistance
Bilal Nawaz
Hello Faisal,
I think from NXOS v5.x.x Cisco have removed the http feature as it is a security risk, it was there in v4. Instead of using device manager, you may need to use fabric manager from Cisco - this includes the device manager features. Enabling the http feature only allowed the device to be managed via DM i think.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/fund/fm/fmfund_5_0_1.html
Please see here also:
https://supportforums.cisco.com/thread/2101256
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
