09-18-2018 10:20 AM
This is a first time using this discussion board,
So i have a 2911 with a SM-X-ES3-24-P module using c3560e-universalk9-mz.150-2.SE6.bin
IOS.
Now when attempting to update the IOS to c3560e-universalk9-mz.150-2.SE11.bin I get the error.
Error: hardware not supported by firmware.
 Try loading newer software instead.
 System Resetting...
When that happens the switch module goes into a boot-loop.
and when I recover the switch module. It loads up what appears to be a temporary IOS c3560e-universalk9-mz.150-2.EJ.bin
Now my question is anyone else having an issue loading the newest IOS into the switch module?
if not which IOS are you using? And could I be doing something wrong?
09-18-2018 11:14 AM
150-2.EJ is the default (and minimum required) release.
Does this also happen with a 10a/10/9/8/7 or lower release ?
09-18-2018 11:28 AM
