Help to configure 2911 router
t
Hi All,
My company recently order a new circuit for our VoIP use and we have a Cisco 2911 router.
The new circuit is terminated with a ethernet handoff. I have never configure a router direct connect to ISP circuit before, please help!
Following details is give by the ISP:
WAN IP
IPv4 Network Address:   X.X.6.204/30
IPv4 Customer Address:   X.X.6.206/30
IPv4 PE Interface Address:   X.X.6.205/30
LAN IP
IPv4 Static Routing :   X.X.159.0/29
Default GATEWAY: X.X.159.1
Available Addresses: X.X.159.2 - X.X.159.6
Subnetmask: 255.255.255.248
VLAN Tagging :Transparent
DNS Server: 198.6.100.6, 198.6.1.125
Reza Sharifi
On the circuit (interface) connecting to your provider you need to add this IP
X.X.6.206/30
example:
interface f0/0
ip address X.X.6.206 255.255.255.252
no sh
On the interface connecting to your lan you need to add this IP:
X.X.159.1
example:
interface f0/1
ip address X.X.159.1 255.255.255.248
no sh
below range is used for your LAN side (PC, server, etc..) with default gateway being X.X.159.1 255.255.255.248
Reza Sharifi
X.X.6.206/30
example:
interface f0/0
no sh
X.X.159.1
example:
interface f0/1
no sh
Thank you! I'll let you know how it goes.
Thank you for your help! I am greatly appreciate.
