Help with TFT on 6500 Using Different Vlans and VRF
armartinez
.  I have tried to test copy tftp: numerous time with no success.  I believe the reason it is failing is my laptop to Ethernet port is in vlan 62 and the tftp process operates in a different IP space.
  I am using gig 7/1 and configuring my laptop nic for x.x.x.254 mask 255.255.255.0.  I can ping from laptop to gateway) and I can ping from the switch to my laptop using ping vrf production x.x.x.254.
Can you tell me what vlan I need to set my laptop connection in or if there is something else I need to change to make tftp work on vlan62?
Does TFTP only work in vlan1 or can it be changed?
Reza Sharifi
If you vlan 62 already is in that switch, than just add  port Gig7/1 to it and also add the interface to vrf production.
Thank you for the response.
I cannot add the iterface to the vrf due to the ios version not allowing it.  That is the main reason we need to upgrade the ios and, the reason I am trying to get TFTP to work.
I have tried the "ip tftp source-interface Vlan62"
