Help !?
blue4cisco
we hv a 1750 router . my problem is that when I surf web using no proxy option from IE I can use audio video facility ,while i chose proxy setting i can not use audio, video facility. I am using Youngzsoft proxy server.where is the problem ?
scottmac
Level 10
Level 10
It sounds like an MTU problem.
When you use a proxy, it adds a tag to the frame / packet(?) that may cause the size to exceed 1500 bytes.
Most real-time packets are not fragmentable, if it can't be fragged, it gets dropped.
Try setting the MTU down to ~1476 and see if it works for you.
Good Luck
Scott
