High CPU Utilization with NTP
forumhealth
I have an old 2501 router (IOS 11.3(11b)T5) which I want to use as an NTP server (it is not used for anything else). I configure two external NTP servers, no problem. CPU utilization is around 5-8%. I then configure "ntp broadcast" on interface e0, and within seconds, CPU utilization is 98%, and the NTP process shows 40%+. If I disable NTP completely, CPU utilization goes back down to a 5% right away. I tried this on another router, and got exactly the same result. This is the only site at which I have seen this. Any ideas on what could be going on on my network which would cause this behavior?
forumhealth
By the way, IP Input utilization on this router also goes way up, more than 20%.
