hold-queue parameter<Output queue 0/1024, 745838161 drops>
lawwm
Hi All,
Recently, I found out that it's something wrong with the parameter about hold-queue.
Below is the configuration. When I issued show interface 3/0/0, I can see the output queue is increasing a lot with 5 seconds.
I've compared other site of the router. When the hold-queue in and out are the same there is no out queue-drops.
Any idea?
Current configuration : 232 bytes
interface GigabitEthernet3/0/0
description *** Physical Interface to the Celcom SDH network ***
mtu 1600
no ip address
no ip directed-broadcast
load-interval 30
negotiation auto
hold-queue 2048 in
hold-queue 1024 out
end
RouterA#show interfaces gigabitEthernet 3/0/0
GigabitEthernet3/0/0 is up, line protocol is up
Hardware is GigabitEthernet, address is 0017.0e2b.4d00 (bia 0017.0e2b.4d00)
Description: *** Physical Interface to the Celcom SDH network ***
MTU 1600 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 126/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is autonegotiation, media type is LX
output flow-control is on, input flow-control is on
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w4d
Queueing strategy: fifo
Output queue 0/1024, 745838161 drops; input queue 0/2048, 0 drops
RouterA#sh int gigabitEthernet 3/0/0
MTU 1600 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 130/255
Output queue 0/1024, 748766847 drops; input queue 0/2048, 0 drops
Here is the config of Router B with the same parameters
Current configuration : 266 bytes
interface GigabitEthernet3/1/3
mtu 1600
no ip address
no ip redirects
no ip proxy-arp
load-interval 30
negotiation auto
hold-queue 1024 in
hold-queue 1024 out
RouterB#show int gigabitEthernet 3/1/3
GigabitEthernet3/1/3 is up, line protocol is up
Hardware is GigabitEthernet, address is 0019.e72e.7613 (bia 0019.e72e.7613)
MTU 1600 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 11/255
Last clearing of "show interface" counters 15w5d
Output queue 0/1024, 0 drops; input queue 0/1024, 0 drops<<<no drop
Available Bandwidth 911496 kilobits/sec
Joseph W. Doherty
At least with the information you've posted, the important difference is likely the output load on RouterA vs. RouterB, load 130/255 vs. load 11/255.
Input queues and output queues don't need to balance, and input queues are often not congested since the input link sets a cap on the inbound rate.
A 2,048 deep output queue is rather large. It's counter to what you might expect, but a too deep queue can actually contribute to drops and poor performance.
What type of devices and IOS are Routers A and B? What's the nature of the traffic?
IOS (tm) GS Software (C12KPRP-K4P-M), Version 12.0(32)S3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 09-Jun-06 22:13 by leccese
Image text-base: 0x00010000, data-base: 0x05159000
ROM: System Bootstrap, Version 12.0(20040128:214555) [assafb-PRP1P_20040101 1.8dev(2.83)] DEVELOPMENT SOFTWARE
BOOTLDR: GS Software (C12KPRP-K4P-M), Version 12.0(32)S3, RELEASE SOFTWARE (fc1)
uptime is 2 years, 3 days, 11 hours, 40 minutes
Uptime for this control processor is 2 years, 3 days, 11 hours, 40 minutes
System returned to ROM by Stateful Switchover at 12:52:19 MY Mon Aug 14 2006
System restarted at 19:37:36 MY Fri Aug 25 2006
System image file is "disk0:c12kprp-k4p-mz.120-32.S3.bin"
cisco 12416/PRP (MPC7457) processor (revision 0x00) with 1048576K bytes of memory.
MPC7457 CPU at 1263Mhz, Rev 1.1, 512KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Traffic will Data and Voice.
I've changed to 1024. But no luck. I also tried 2048 for in and out. Still the same. the queues counter still increasing.
You are right, the Load both router do not equal. Do you have any idea?
Appreciate your input
I've not worked with a 12,000 series router. Looking over the documentation, you might be able to implement QoS features beyond using a simple FIFO queue. You could experiment with WRED and/or FQ.
Assuming TCP is the bulk of your traffic, if the output link is oversubscribed, it's normal to see drops, especially as flows attempt to use all bandwidth. However, what you want to obtain is the minimal amount of drops at peak usage. A large FIFO queue might allow multiple flows to all ramp up and then has them all fall into slow start with (global) synchronous tail drops. Both WRED and/or FQ might avoid the synchronous tail drops, both improving overall throughput and, surprisingly, often reducing overall drops.
Unsure whether the following can be configured on your interface, but try this:
policy-map yourname
class class-default
fair-queue
random-detect
(RouterA)
interface gigabitEthernet3/0/0
service-policy output yourname
