How can I disconnect two sessions
burleyman
Level 8
Level 8
I have two sessions that I need to disconnect. How can I do this from a console session?
Here is the show user output
4506#show user
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:00
1 vty 0 idle 30w2d dgth1.nixonpeabody.com
2 vty 1 idle 9w0d 10.10.4.2
3 Accepted Solutions
chrihussey
Try the following commad from enable mode:
"clear line vty X", where X = line 1 or 2
ankbhasi
Hi Friend,
Can you try "clear line 1" & "clear line 2" OR "clear line vty 1" & "clear line vty 2"
If this does not work can you post the output of "show tcp brief".
Ankur
Iain
Level 4
Level 4
Burleyman,
Heres how you do it. Clear line vty (vty number you want to clear)
Example: clear line vty 0
The command above would clear the nixonpeabody.com connection.
6 Replies 6
chrihussey
Thanks....Worked great.
ankbhasi
Hi Friend,
Ankur
Iain
Level 4
Level 4
Burleyman,
