How stp BPDU communicate between cst,pvst and mst spanning tree mode
ccnp_ccie
i am facing pvid inconsistancy and type inconsistancy problem in my network.
network connectivity
Sw1----------------Sw2--------------Sw3
sw1 is cisco siwtch(spanning tree mode pvst+)
sw2 is extreme switch(spanning tree mode is CST,it is work on cst only)
Sw3 is cisco (spanning tree mode pvst+)
Amit Singh
Hello friend,
Please see this link below, this will help you:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00801d11a0.shtml#topic1
HTH,Please rate if it does.
-amit singh
Francois Tallet
Level 7
Level 7
Make sure you are using the same native vlan on the link between Sw1/Sw2 and Sw2/Sw3.
Else, run MST on sw1 and sw3.
Francois
Oh, my previous email was for the pvid inconsistency. Make also sure that you're trunking on those two links;-)
If this still does not help, please, tell us exactly what inconsistency message you get, on which port, and the trunking configuration of the different ports involved.
F.
