How to check invalid packet on switch 6500?
vampirepong
I found this log on Switch 6500 at below.
%EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC: Non-fatal interrupt Packet Parser block interrupt
I search from cisco.com  for workaround this issue. I need to know cause about MLS log. Please tell me know, how to check invalid packet with this issue?
Why web tell used no mls 3 command for diable log?
Amnaj P.
Thiyagu VG
Found some description about this error logs in Cisco site,
"Apr 20 17:53:38: %EARL_L3_ASIC-SP-3-INTR_WARN: EARL L3 ASIC:
          Non-fatal interrupt Packet Parser block interrupt"
The error message %EARL_L3_ASIC-SP-3-INTR_WARN indicates that the Enhanced Address Recognition Logic (EARL)
Layer 3 (L3) application-specific integrated circuit (ASIC) detected an unexpected non-fatal condition.
This indicates that a bad packet, probably a packet which contains a Layer 3 IP checksum error, was received
and dropped. The cause of the issue is a device on the network that sends out bad packets. These issues,
among others, can cause the bad packets: Bad NICs; Bad NIC drivers; Bad applications
In older Cisco IOS Software releases, these packets are normally dropped without being logged.
The feature of logging error messages about this problem is a feature found in Cisco IOS Software
Release 12.2SX and later.
Workaround; please click: "http://www.ciscopress.info/en/US/products/hw/switches/ps700/products_tech_note09186a00801b42bf.shtml"
Hope this helps.
Cheers,
ThiyaguVG.
Message was edited by: Thiyagu Muthukumar Ganesan
Thiyagu VG
Hope this helps.
Cheers,
ThiyaguVG.
