How to Check Port Flapping
Dear All,
We are having 4500 Cisco Core Sw. It seems some of the Uplinks are flapping and i dont exaclty know where its happening.
can someone help how to troubleshoot this issue,
10 Replies 10
Leo Laohoo
In Catalyst 4k platform, the default settings for port configurations is "NO logging event link status".  Is this the case?
what is connected to these uplink ports ?
Server Switches, HX etc
the reason I am asking is that the problem can also be the connected device(s), rather than the Cisco 4500. What do the logs on both devices (if the logs are available) show ?
under each interface not in global mode.
450x(config-if)#logging event ?
link-status UPDOWN and CHANGE messages<-
can i run this command in Live environment ..wont be any memory utilization issue..
Hello
Are this uplinks trunk or access ports?
sh spanning-tree int x/x detail | in transitions
sh int | inc L2|line|broadcast
sh int | in line|\/sec
sh int x/x counters
Kind Regards
Paul
These are uplinks, can you be more specific about the commands..
Post the configuration of the interface in question.
If the command "logging event link-status" is not in the configuration of the interface this means flapping link ports are not visible in the logs (the command "NO logging event link-status" is hidden, by default).
Mark Elsen
            - Check the logs on the 4500 for more info.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
