How to configure A/V Switch
Mrfox
I have a stack of 3 9200L-24P-4G used for audio and video devices, it needs some special configuration according to the vendor quick guide, I haven't configured some of the settings and need some help on finding out how to enable them.
I'm using VLAN 1000 for all devices on the switch and has only 1 Layer 3 Uplink for connectivity with the rest of the network and the internet. Screenshot 2021-06-23 162756.png
pieterh
individual commands can be found in this document Cisco IOS IP Multicast Command Reference
som practical info in this document  IP Multicast: IGMP Configuration Guide, Cisco IOS XE Release 3S
Reza Sharifi
For A/V, usually, you don't need any of this configuration if you are using the ports for Webex, Zoom, display, camera, and touch panels in the conference rooms. The communication between the end device and Zoom or Webex cloud is all unicast. It is however a good idea to put all the A/V equipment in a separate vlan/subnet and not mix them with your data and voice VLANs.
