How to configure STP in Cisco?
abbas64
I am configuring a small network with one router (also a DHCP server), 5 switches. All switches are connected to each other Gigabitethernet.
I have configured VLANs on the switches and configured DHCP pools on the router. I have also configured one router to act as root switch or root bridge using following command:
Root switch does not have any VLANs configured. Other switches have VLAN configured with IP addresses assigned.
spanning-tree vlan 1 root primary
The problem is I can't ping any computer or a switch from another switch. All switches are directly connected to each other, but I still can't ping.
I have attached an image of my network topology.
I am using 2960 switches.
20 Replies 20
when you do a 'show vtp status' on your switches, do all of them have the same amount of VLANs ? What do the trunks look like that connect the switches ?
Can you post the configs of two neighboring switches ?
Result of "show vtp status" from switch where I created ALL vlans and assign addresses to VLANs:
Switch#show vtp status
VTP Version : 2
Configuration Revision : 6
Maximum VLANs supported locally : 255
Number of existing VLANs : 11
VTP Operating Mode : Server
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x5B 0x1A 0xF3 0x57 0x2D 0x7E 0xA0 0x30
Configuration last modified by 0.0.0.0 at 3-1-93 00:01:45
Local updater ID is 195.165.85.33 on interface Vl5 (lowest numbered VLAN interface found)
Result of "show vtp status" from switch with only VLANs that it needs:
VTP Version : 2
Configuration Revision : 3
Number of existing VLANs : 8
VTP Domain Name :
MD5 digest : 0x6A 0x5D 0x5F 0xCF 0xAA 0x2E 0x47 0x45
Configuration last modified by 0.0.0.0 at 3-1-93 00:06:22
Local updater ID is 0.0.0.0 (no valid interface found)
Configuration of switch with ALL VLANs:
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/2
switchport access vlan 15
interface FastEthernet0/3
switchport access vlan 20
interface FastEthernet0/4
switchport access vlan 25
interface FastEthernet0/5
switchport access vlan 30
interface FastEthernet0/6
switchport access vlan 5
interface GigabitEthernet0/2
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan5
ip address 195.165.85.33 255.255.255.224
interface Vlan10
ip address 195.165.85.65 255.255.255.224
interface Vlan15
ip address 195.165.85.97 255.255.255.224
interface Vlan20
ip address 195.165.85.129 255.255.255.224
interface Vlan25
ip address 195.165.85.161 255.255.255.224
interface Vlan30
ip address 195.165.85.193 255.255.255.224
Configuration of other switch:
One more thing I changed the root switch using following command:
spanning-tree vlan 1 root primary --> I said vlan 1 because root switch does not have any vlans, but the default vlan 1.
it doesn't really matter where the root for VLAN 1 or the other VLANs is, as they can be different for each VLAN.  Anyway, you should see the same amount of VLANs on each switch. Common problems are different VTP versions on the switches. If you issue a 'show vtp status' on the other switches, check if the VTP version is the same on all.
When you do a 'sh cdp neighbor' on the root switch, are all the client switches listed ?
Yes, all switches have version 2 or same version running. The output of "show cdp neighbor" is:
Switch#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
Switch Gig 2/1 143 S 2960 Gig 0/1
Switch Gig 5/1 120 S 2960 Gig 0/1
Switch Gig 4/1 165 S 2960 Gig 0/1
Switch Gig 3/1 165 S 2960 Gig 0/1
Switch#
So in brief I have vlans configured on all 4 switches, the switch in the middle (in picture) is the root switch, dhcp is configured on router.
But no connection or no ping.
When I try to ping one switch from another switch all packets are broadcast.
Stupid question maybe, but do you have 'ip routing' enabled on the root switch ?
I am using Cisco layer 2 switches, so I think I can't enable ip routing.
Just so that I understand: when you do a 'show vtp status' on one of the client switches, it shows the same amount of VLANs, but you cannot ping a device in the same VLAN ? Which VLAN is your management VLAN ?
In addition, all your switches have an IP address in the same VLAN ?
No, not all switches have same amount of VLANs.
The switch where I configured all VLANs has 11 and other switch have 8.
OK. Can you post the output of 'show int trunk' from the core switch ?
show int trunk:
there is a blank line, no output. Plus why do I need trunking on root switch?
You need trunking on every switch, including the root. The output of 'show cdp neighbor' shows you the local and the remote ports that need to be configured as trunks. The configuration of the trunk ports should look like this:
switchport nonegotiate
It might be easier if you post the full configuration of the core switch and one of the neighbor switches. That way, I can check if something is missing.
"Show running-config" from core switch:
Switch#show running-config
Building configuration...
Current configuration : 529 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree vlan 1,5,10,15,20,25,30 priority 24576
interface GigabitEthernet0/1
interface GigabitEthernet1/1
interface GigabitEthernet2/1
interface GigabitEthernet3/1
interface GigabitEthernet4/1
interface GigabitEthernet5/1
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
"show running-config" from client switch:
Current configuration : 1618 bytes
version 12.2
hostname Switch
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan5
interface Vlan10
interface Vlan15
interface Vlan20
interface Vlan25
interface Vlan30
line con 0
line vty 0 4
login
line vty 5 15
login
end
