how to connect to remote VSS peer
mayambanzumba
I am trying to  connect to the remote vss peer 1 using the below command from my local 6509 switych , but I always remain on the same switch when I do a show version command. Is there another command to remotly connect to the peer switch?
6509#session switch 1 slot 1 processor 0
6509#sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 2
Local switch operational role: Virtual Switch Active
Peer switch number           : 1
Peer switch operational role : Virtual Switch Standby
Reza Sharifi
Why are trying to connect to the stand-by switch?  All configs must apply to the primary switch.
