How to create separate subnets in network
mahesh18
Level 6
Level 6
Hi all,
I have home newtorl of 2 routes 3 layer 2 and 1 layer 3 switch.
Right now they all are in 1 network --means same subnet.
how can i create different subnets and make inter vlan routing any ideas
thanks
mahesh
22 Replies 22
Hi Jon,
Thanks for reply.
so right no i am doing 1 step at time as below
i connected my layer 3 switch with router
3550SMI#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.5.1 to network 0.0.0.0
C    192.168.30.0/24 is directly connected, Vlan30
C    192.168.10.0/24 is directly connected, Vlan10
C    192.168.20.0/24 is directly connected, Vlan20
     192.168.5.0/30 is subnetted, 1 subnets
C       192.168.5.0 is directly connected, FastEthernet0/11
S*   0.0.0.0/0 [1/0] via 192.168.5.1
3550SMI#sh run int fa0/11
Building configuration...
Current configuration : 166 bytes
interface FastEthernet0/11
description Lan connection to 2650XM Router
no switchport
ip address 192.168.5.2 255.255.255.252
spanning-tree bpduguard enable
end
i am able to ping the router ip as below but can not ping the internet and also not getting ip address from layer 3 switch
3550SMI#ping 192.168.5.1
Sending 5, 100-byte ICMP Echos to 192.168.5.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
3550SMI#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
3550SMI#
DHCP config
ip routing
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.5.2
ip dhcp excluded-address 192.168.5.1
ip dhcp pool Cisco
   import all
   network 192.168.1.0 255.255.255.0
thanks
mahesh
Hi jon
here is router config
2650xm#sh ip route
Gateway of last resort is not set
C       192.168.5.0 is directly connected, FastEthernet1/0
2650xm#ping 192.168.5.1
2650xm#ping 192.168.5.2
Sending 5, 100-byte ICMP Echos to 192.168.5.2, timeout is 2 seconds:
2650xm#
mahesh18 wrote:
3550SMI#sh ip route
no switchport
end
U.U.U
3550SMI#
Mahesh
You will need to make sure the router is setup correctly. You will need to setup NAT on the router for your private addressing. Also you need a default-route on your router pointing to the next-hop for the internet. Can you ping an internet address from the router ?
Jon
Ho jon
fro router i can ping the internet
2650xm#ping 4.2.2.2****************************************************************************ping to internet IP
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/49/52 ms
2650xm#sh ip route
S    192.168.30.0/24 [1/0] via 192.168.5.2
S    192.168.10.0/24 [1/0] via 192.168.5.2
S    192.168.20.0/24 [1/0] via 192.168.5.2
2650xm#'
problem is
1> from switch no ping to internet
U.U.U
3550SMI#sh ip route
3550SMI#
2>>>>>>>from layer 3 switch no ip is assigned to PC  so not working as dhcp
here is nat on router config
interface FastEthernet0/0
description WAN Connection to ISP modem
ip address dhcp
ip access-group 102 in
no ip redirects
ip accounting output-packets
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet1/0
ip address 192.168.5.1 255.255.255.252
ip access-group 103 out
ip nat inside
duplex auto
speed auto
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 deny   icmp any any echo log
access-list 102 permit ip any any
Let me know how we can solve these 2 issues for time being
many thanks  jon
Mahesh
You only have one DHCP pool configured on the 3550 switch -
ip dhcp pool Cisco
   import all
you need one for each vlan subnet so you will need a pool for -
192.168.10.0/24
192.168.20.0/24
192.168.30.0/24
also you don't need this -
because you are not handing out any IPs from the 192.168.5.0 pool.
In addition for each pool you need to add a default router so your config should look like -
ip dhcp pool vlan10
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool vlan20
   import all
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
and one for vlan 30 as well.
If you are not allocating any end devices eg. PCs etc. into vlan 1 then you don't need the Cisco DHCP pool. You only need pools for the vlans you are allocating end devices into.
Your NAT -
You currently have this -
you will need to add extra lines for each new address range eg.
access-list 101 permit ip 192.168.5.0  0.0.0.3 any
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
etc..
Jon
Hi Jon,
thanks for great reply
i did exactly as you mentioned   for ip dhcp pool for 3 vlans
but for access -list i did 192.168.0.0 0.0.255.255
after this i am able to ping the internet from switch and pc but not able to open web sites.
many thanks
mahesh
Hi Jon,
I am able to ping internet sites from switch router and pc but unable to open internet sites.
also when i do ipconfig /all on pc it do  not show ip address
from switch and router i am able to ping the internet sites with www.yahoo.com   but not from pc.
i also try to add the isp dns servers with command
ip name server in switch still same thing?
any thoughts
mahesh
Hi Jon,
Now internet is working fine on all pcs.I can access the websites.
this is what is did under  each  Vlan 10,20, and 30  in layer 3 switch  i add the command
dns-server 64.59.135.143
Now when i do ipconfig on pc i see DNS  server as  64.59.135.143.
Many Many thanks for all your help during this all work.
I learned lot of stuff from  you still lot to learn!!.
Best regards
Mahesh
