How to Enable IP Accounting in Cre switch Running cat OS
roopesh.n
Hi All ,
Can any one tell
How to Enable IP Accounting in Cre switch 4000 Running cat OS and Cisc ASA 5510 (8.2 )
Roopesh
Ivan Shirshin
Hi Roopesh,
I think IP accounting is not supported on the 4500. You can use a netflow alternatively:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/configuration/guide/nfswitch.html
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Hi Roopesh,
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
