How to make portchannel between layer 2 and layer 3 switch?
rrairineo1
can i configure a layer 2 switch with a layer 2 etherchannel and on the other side a layer 3 switch with a layer 3 etherchannel? can this work?
2 Accepted Solutions
Mark Malone
No it needs to match both sides c, cant be ip based on l3 and not on l2,so it has to be layer 2 each side only
just bundled trunk ports really like below , far side would be channel-group active if using lacp
interface Port-channel10
 description xxxxxxxxxx
 switchport trunk allowed vlan 1-1005
 switchport mode trunk
interface GigabitEthernet1/0/3
 channel-group 10 mode desirable
interface GigabitEthernet1/0/4
devils_advocate
Level 7
Level 7
Nope, fraid not.
You can have a L2 both sides.
You can't have a L2 Trunk one side and a L3 interface the other side.
Just because its a L3 doesn't mean it only does L3 functions, you can happily have a L2 etherchannel between a L2 switch and a L3 switch.
Mark Malone
devils_advocate
Level 7
Level 7
Nope, fraid not.
