how to redistribute default route into both eigrp & BGP using ACL
Dr.X
Level 2
Level 2
hi ,
assume i have
EIGRP 1 WITH ASN1 ===================EIGRP 2 WITH ASN2
assume  IN eigrp 1 , there is a defualt route and we want to redistriube obly this route to asn 2
note that  the default route is in the routign table ,
note that typing
network 0.0.0.0 0.0.0.0 under eigrp command  is uncorrect .
my question is how to redistribute the default route in to eigrp using ACL  ?
im concentrating about the ACL wt i need to type in the ACL .
regards
cadet alain
is the default route a default static route already redistributed into EIGRP  1 with redistribute static command?
if so it appears in the topology table  for EIGRP 1 of the router with the 2 EIGRP ASes .
Do you want to redistribute this prefix only in EIGRP 2 and does it have to be with an ACL, not a prefix-list?
Regards.
Alain
yes ,  i want only to redistribute the defualt route
I WILL Type :
rediatribute static route-map xxx
and the route map will refer to ACL which match only a defualt route connected on the router .
plz i want all the possibilities of typing the ACL
Here are a few ways to match the default route in order to filter or allow in routing updates.
Using ip prefix-list (the preferred way)
ip prefix-list MATCH_DEFAULT seq 5 permit 0.0.0.0/0
using ACLs (least preferred method)
standard ACL
access-list 1 permit 0.0.0.0
Sorry this was a little vague.  Here are a few examples for EIGRP and BGP:
EIGRP
In the following example, EIGRP process 1 is configured to accept two networks, the default network 0.0.0.0 and network 10.108.0.0:
access-list 1 permit 10.108.0.0
access-list 1 deny 0.0.0.0 255.255.255.255
router eigrp 1
network 10.108.0.0
distribute-list 1 in
BGP
In this example BGP is configured to deny the network 10.10.10.0/24 from the BGP neighbor 172.16.1.2.  Example:
access-list 1 deny 10.10.10.0 0.0.0.255
access-list 1 permit any
router bgp 100
neighbor 172.16.1.2 remote-as 200
neighbor 172.16.1.2 distribute-list 1 in
Brian
