Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to reload/reboot switch with a different flash file
vkasbarian
Hi folks,
Im a rookie and in my 3rd semester towards CCNA...I'm working in PKT and trying to reload a Switch from a different file in the flash list. I tried a few sytaxes with no luck . I want you expertise on this matter, thanks  TXT file is attached
Reza Sharifi
Reza Sharifi
The command is "boot flash
Here is the command reference guide with example:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/command/reference/bootldr.html#wp1118871
Reza
Thank you Reza........it did work!
