How to remove multiple static arp entries
Wei Wei
There are so many static arp entries in my switch 3550.
I know I can use the command: no arp xxx . xxx . xxx . xxx to delete a static entry.
Can I do that within a command?
or Any other good suggestions?
Mark Malone
There is no global command to remove them all at once unfortunately , they have to be manually removed line by line , unless you can write some script but that will probably take just as long
Mark Malone
Hi mark,
Thanks for the reply. I think the best way that I can do is to write a script.
