How to remove Port-channel from SG300
Rogger Melly
Hi All
You would think it a very simple command to remove a port channel but apparently not when it comes to the SG300.
I have removed any reference of the Port Channel from the interface's it was assigned to now all I have left is the Port-channel 1. I have tried #no int port-channel 1 (this is an unrecognized command)
I have also tried;
int port-channel 1
no trusted
no switchport mode
no switchport trunk allowed vlan
no switchport trunk native vlan
After all the above it's still in the configuration, has anyone managed to solve this issue?
Seb Rupik
Hi there,
You can't. If you look at sh int status you'll see port-channels 1 - 8 , which are present by default and none of which can be removed.
At best, as you have found, you can remove the config and port membership.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
That's pretty poor on Cisco's half - This make's sense as when you first login via CLI you can't see any ports until you put configuration on them.
