HSRP Question...
CiscoBro
Is there a way to associate HSRP failover with some Layer 2 interface failover.
For example HSRP ip (Vlan 100 with ip 172.20.61.1) is active on router #1, if Router #1 fails, (Vlan 100 172.20.61.1)  will be active in Router #2.
Is there a way when an interface, let's say Gi1/0 in router#1, configured as switchport access Vlan100, goes down, use it to trigger Vlan91 failover to secondary switch?
Reza Sharifi
You can track the interface.
http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/13780-6.html
http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/9234-hsrpguidetoc.html#intracking
Reza Sharifi
