hsrp with bgp
prashantrecon
We want to configure bgp with hsrp .We have nearly 10 site to site tunnels.
If we go head with above config is there any problemn we  can face regarding site to site tunnel.
Vivek Ganapathi
Level 4
Level 4
Clarity required on your question. Can you please share a topology of the setup?
Vivek
Hi vivek,
I have router and firewall placed  behind router.we are planiing to purchase another router so that we can implement
hsrp .Currently i have two links terminated on router with bgp running.
On firewall nearly 10 site to site tunnel are running.
My question is if i implement hsrp will this effect the tunnel.
With hsrp if active router goes down and then standy will become active this may effect tunnel.
Hi prashanth,
As you have IPSEC terminated behind your routers., a stateful failover of IPSEC vpn's is not achievable. You will have a tunnel drop for a period of time & then reestablish. If you were to terminate the ipsec tunnels on the router, then a stateful failover is possible (depends on your hardware support).
Vivek
