I have problem with Traceroute
Hi all
I have Linux servers and router for voice all in same vlan connected to core switch 4500  direct when i Tracert server ip from my PC or frome core there is one server will reatch to core and geve ***
this problem just only on one server other servers and Router is  okay and i check the CDP for all interface is UP
12 Replies 12
Ganesh Hariharan
Hi all
Need some clarfication where is this server is located is it in different vlan and is connected to different switch.
Ganesh.H
Ganesh.H
The server connect to core switch direct and in the same VLAN
How may NIC you are using for that server.
Please can you check that routing table for that particular server & Compare with any other server.
Chetan Kumar
Chetan Kumar
There is tow interface cards in this server connected to same switch.
from the switch i can ping the tow interfaces and vice versa.
alkaff
Ganesh.H
If it is directly connected with the switch it should ping from the switch if you have configured svi for that vlan and check are you able to learn the mac-address of the server in switch.
And also check are you able to ping from server to switch or any other server in the same vlan.
Hope to Help !!
Ganesh.H
I can ping from both side . regarding the mac address switch learn for one interface
show the result of command:
ELC-CORE-1#sh mac-address-table int g3/5
Unicast Entries
vlan   mac address     type        protocols               port
  30    0023.7d93.a08e   dynamic ip                    GigabitEthernet3/5
Multicast Entries
vlan    mac address     type    ports
  30    ffff.ffff.ffff   system Gi2/1,Gi2/2,Gi2/3,Gi2/4,Gi2/5,Gi2/6,Gi3/3
                                Gi3/4,Gi3/5,Gi3/6,Gi3/7,Gi3/8,Gi3/17,Gi3/24
                                Te1/2,Switch
ELC-CORE-1#sh mac-address-table int g3/7
Multicast Entries
                                Te1/2,Switch
Unicast Entries
Multicast Entries
                                Te1/2,Switch
Multicast Entries
                                Te1/2,Switch
As narendra said can you brief with scehmatic diagram now where are you getting rto when ever you are pinging this server.
Ganesh.H
I would appreciate you to eloborate on this issue.
Rgds,
Narendrakumar B
I am attached herewith the network design it is very simple.
If all are in same vlan and is directly connected with switch what OS is running on the problematic server and is any firewall or anti virus is running on that server,If possible can you take capture for that server when ever you tarcert the servip from other servers.
and i dont have visio to see the attacehd diagram.
Hope to Help !!
Ganesh.H
The OS is Linux the firewall is disable and there is no anti virus. When I trace from the problematic server I reach to core switch and servers
I send doc with capture i hope it's clear
Really strange but it is sure it related to linux server specific as traceroute packet will be reaching till linux server and as far my knowledge some devices will prevent traceroute packets directed at their interfaces, but will allow ICMP packets. Using traceroute with a -I flag forces traceroute to use ICMP packets that may go through.
And i dont think you would be facing any problem with the application running on these servers it just trace route packet issue with this server.
Hope to Help !!
Ganesh.H
