IE4000: System boot up failure
EHC team 82
Dear all,
We're an infrastructure company employing Cisio IE-4000 series product (S/N: FDO2348J62U; PID/VID No.: IE-4000-8T4G-E V02) for our application control system.
However, that set mentioned above boots up unsuccessful and hangs. Please find the attached status file for your reference. Furthermore, each time it hangs we heard a "click" sound like a relay switched.
Would you please show us how to solve this problem. Thank you and warmest regards,
James
5 Replies 5
Leo Laohoo
RMA the switch
Mark Elsen
   - You don't have any attachments in the post ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
FYI
  - Try a factory reset ; if that does not help then the device is probably broken ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
EHC team 82
FYI
