Inter vlan communication bandwidth issue
prem.ce24
I am facing Inter vlan communication bandwidth issue.
In N6K when i am transferring data between same VLAN geeting good transfer rate nearly 300 Mbps.
But when i am transferring data between D/F VLAN getting transfer rate in Kbps.
What is issue any one help me to resolve the issue.
You can create virtual subinterfaces on a parent interface configured as a Layer 3 interface. A parent interface can be a physical port or a port channel.
Subinterfaces divide the parent interface into two or more virtual interfaces on which you can assign unique Layer 3 parameters such as IP addresses and dynamic routing protocols. The IP address for each subinterface should be in a different subnet from any other subinterface on the parent interface.
please check the below link for more info:-
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus6000/sw/interfaces/6x/b_6k_Interfaces_Config_Guide_Release_6x/b_6k_Interfaces_Config_Guide_Release_602N12_chapter_010.html
