interface down no green lights for connectivity
shabazhussain
hi guys
am new to routing ,
am using pix 515e and internet  router 1840 cisco
i have cofigured two interfaces  e 0/0  of both pix and router
router
internet router fe0/1 is outside
internet router fe0/0 is inside
? pix firwall e0/0 is outside directly connected to router e0/0 inside
? their is no green lights of connectivity    ...... why ..
and when i checked router
show interface
interface is up  , line protocol is down
please let me know the solution for the problem
regards
shabazhussain
8 Replies 8
Giuseppe Larosa
Hello Shabaz,
you probably need a cross-over cable:  I expect both NICs to behave like a PC NIC and no one has MDIX capabilities
or you put a LAN  switch in the middle and you use two straight cables to connect the PIX and router interfaces to two ports in the same Vlan
see
http://en.wikipedia.org/wiki/Ethernet_crossover_cable
Hope to help
Giuseppe
hello
thanks for ur suggestion
i have tried with cross cable then  to it did not solve
cable connected to
interface at router e1  to pxi e1
physicallly no lights turns green
what could be the cause
regards
shabaz
Hello Shabaz,
you should verify if the interface is enabled on the PIX side also
what is the output of sh interface on the pix?
Hope to help
Giuseppe
hi guys
router
? pix firwall e0/0 is outside directly connected to router e0/1 inside
show interface
reagards
shabaz
hi guys
router
show interface
reagards
shabaz
Hi Shabaz,
Just to isolate where is teh issue if you have switch just connect pix interface with switch port and see if port is coming or not or from router inetrface to switch port and see router interface is coming up or not and possibily just paste also the show interface of router and pix side.
Ganesh.H
hi ganesh
i did that
by connecting pix e0 int to switch port    its showing me green lights ( line is up )
same on router e0 connected to switch   its also shows me green light ( line is up )
what next i should  have to try
regards
shabaz
hi ganesh
i did that
regards
shabaz
Hi Shabaz,
It shows that cable is not having any issue and what is the interface out at router interface and pix interface
Ganesh.H
Ganesh Hariharan
hi guys
am new to routing ,
router
show interface
regards
shabazhussain
Hh Shabazhussain,
Try connecting standard Category 5 Ethernet patch cable is ideal for use for connecting systems to other devices in network,check out the below link for network latout with PIX 515E.
http://www.cisco.com/en/US/docs/security/pix/pix72/quick/guide/instal_p.html
Hope to Help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
