Interface with 2 addresses into hub routing error
robertsaye
Hi all,
I have a very basic setup. I have a 2621 with 2 FE ports. On one of the ports, I gave it an IP address of 10.x.x.199/16 (10.2.255.255 is our lab network). Then I gave it another IP address of 192.169.209.2/24. This is an interface on the device I am testing. I run a cable to a netgear hub, then from the hub I have cables to a switch on my lab network and a cable to my DUT.
This seems fairly straightforward so far. Now from my 2621 I can ping anywhere on the 10.2 network. From the 10.2 network, I can ping my Cisco so that connection looks fine.
My issue is on the secondary address. From my DUT I can ping this interface. But from the Cisco, I can't ping my DUT.
Here is my config:
Current configuration : 1056 bytes
version 12.2
hostname iraq
no logging console
enable secret xxx
enable password *******
ip subnet-zero
no ip routing
no ip domain-lookup
call rsvp-sync
interface FastEthernet0/0
ip address 192.169.209.2 255.255.255.0 secondary
ip address 10.x.x.x.255.0.0
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/0.1
no ip route-cache
no ip mroute-cache
interface FastEthernet0/0.2
no ip route-cache
no ip mroute-cache
interface FastEthernet0/1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
duplex auto
speed auto
ip classless
ip http server
snmp-server community public RO
snmp-server enable traps tty
dial-peer cor custom
line con 0
timeout login response 300
absolute-timeout 10000
line aux 0
line vty 0
exec-timeout 0 0
password *******
login
length 0
line vty 1 4
password *******
login
end
Any ideas??? Thanks, Robert
mehrdad
Level 3
Level 3
check extended ping like the below
iraq>enable
iraq#ping
Protocol [ip]:
Target IP address: 192.169.209.x
!--- The address to ping.
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.169.209.2
Mehrdad Arshad Rad
That works correctly...
iraq#ping
Protocol [ip]:
Target IP address: 192.169.209.1
Repeat count [5]:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.169.209.1, timeout is 2 seconds:
Packet sent with a source address of 192.169.209.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
iraq#
I have tried adding a route for this, but can't seem to figure out the one I need.
where do you define route?
In fact when you ping your DUT interface, the source address of echo request is primary address of router, it means 10.2.x.x so when the packet receives at DUT, it hasn't any routes for it so if you define default gateway at DUT to secondary address of router (or a route for network 10.2.x.x), the ICMP reply can route to your router and your ping will be successful from your router.
That worked perfect. I added the route
ip route 10.2.4.0 255.255.255.0 192.169.209.2 20/1
And my connectivity is complete. Thank You very much!
