Internal routing problem - 877W
coruna_74
I'm trying to configure in a 877W a connection to a DSL. With the configuration below, I can ping from the router any Internet address but from any PC on the network I can't. Can somebody tell me what is wrong?
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.15.1
ip dhcp pool dpool1
import all
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
dns-server xx.xx.xx.xx
no ip domain lookup
ip name-server xx.xx.xx.xx
archive
log config
hidekeys
interface ATM0
no ip address
ip nat outside
ip virtual-reassembly
no atm ilmi-keepalive
pvc 8/32
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.15.1 255.255.255.0
ip access-group 100 in
ip nat inside
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 0 xxx
ppp pap sent-username xxx password 0 xxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 192.168.15.0 0.0.0.255
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Jon Marshall
Can you remove "ip nat outside" from the ATM0 interface config and add "ip nat outside" under the Dialer0 interface and then retest.
Jon
Now I can ping Internet addresses from computers inside the network and I can also open connections to ftp servers, but I cannot open web sites through the IE. Any idea?
I have made a few changes in the configuration, and now I've got new problems.
With the conf below the Internet access through LAN goes real slow and the WLAN does not even appear at the computers availables WLANs list.
Any suggestion?
version 12.4
no service pad
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 xxx
no aaa new-model
dot11 ssid cisco1
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 xxx
no ip source-route
ip cef
ip dhcp pool dpool1
import all
no ip domain lookup
username xxx privilege 15 password 0 xxx
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
pvc 8/32
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid cisco1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
power local cck 13
power local ofdm 13
power client 13
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
interface BVI1
ip nat inside
ip http server
ip http authentication local
access-list 1 remark SDM_ACL Category=18
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
