Intra VLAN communication between PC and Camera through C9300 Switch
sujeet20011988
I have to change my camera IP but am not able to do with a stand-alone PC because I have lost the power adaptor. So I decide to the same with the help of switch using either as hub or as switch for intra vlan cummunication.
Issues:
1. Not able to use C9300 as hub
2. As a switch it is allowing me to ping only 4 packets.
Please help me with minimal configuration required to allow communication between PC and camera.
ammahend
your question is not clear, try rephrasing your question again with a topology is possible.
-hope this helps-
