IOS upgrade for VSS SWITCH
dc-csa-blr
can anyone help me how to upgarde IOS in VSS configured switch.
Reza Sharifi
The easiest way to do it is by loading the new IOS into the primary switch flash and the stand-by witch flash.  Make sure to set your boot variable, save your config and reboot both chassis.
This requires downtime and should be done during a maintenance/outage window and not during production hours.
Depending on your current IOS and the new IOS you want to run you can also use ISSU.  see link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/virtual_switching_systems.html#56355
