ip helper address not forwarding
javi1988
Hello all,
I have 2 stacked switches and I have updated the IOS to CAT3K_CAA-UNIVERSALK9 Version 16.3.8
I there a SVI for the vlan where the clients are connected. I have set ip helper-address "DHCP IP" in this SVI, before the update it was working without problems but after the reboot is not forwarding nothing.
If I configure ip helper in a access switch it works.
Any idea?
Thank you for your help.
16 Replies 16
this post is old. What is your current problem ?
We had this issue during more than 11 months and the solution was to update the IOS to a newer version.
