IP Helper_Address Problem 3750
dendazen2000
Hello everyone.
I think it is my last resort for help, as i broke my head already over this problem i am experiencing.
I have stack of 2 switches 3750s for core networking on the site and a stack of 4 2960-s for distribution
My problem is that my DHCP which is Win2008 Server is not working on the vlan interfaces.
It does work on the native vlan 1 which is 192.168.186.1/24
But i have 3 other VLANs(2,3,4:187.1,188.1,189.1).
So teh problem is that when i connect a workstation to VLAN2,3 or 4 i do not get DHCP ip address.
if i connect workstation to VLAN1 either to the core switch port or to any port of the 2960s switches, which assigned vlan1 interface i do get ip address
for the connected workstation.
The thing is when i connect WS to the vlan2,3, or 4 and assign ip address manually i can ping my DHCP server which connected to the VLAN1 port on the core switch and opposite can ping that manually assigned ip from DHCP server.
So i do not know what the problem is and service dhcp command was performed.
Here i am providing config output. of the core switch.
Please if anyone can help with soemthing or what i can do to troubleshoot.
By the way i've tried to us: debug dhcp detail command on the core switch when switching WS to get the ip from DHCP on VLAN2,3 or 4 but no output.
Current configuration : 7583 bytes
version 12.2
no service pad
hostname OpusCoreSwitch
boot-start-marker
boot-end-marker
enable secret 5 $1$AcFb$8eC/HK3tjW7B4wD8j2/bu.
no aaa new-model
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-48ts
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
crypto pki trustpoint TP-self-signed-2680796288
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2680796288
revocation-check none
rsakeypair TP-self-signed-2680796288
crypto pki certificate chain TP-self-signed-2680796288
certificate self-signed 01
  30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363830 37393632 3838301E 170D3933 30333031 30303033
  33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36383037
  39363238 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D4CC 30CD8504 CDFF9238 4B28C001 FB388FA5 8EE5CBFA 6D5EE6D1 C0CC383B
  CD7A94E2 9C0D4063 3EBBC494 0D9BB6A8 7448E8CF 06548C4C 9814670B 70C8EAD8
  D7684AF2 2FA71128 9E8471C5 32252380 A4EA8DA4 A1E8A5DA 4751337B 2E0DD2A4
  9F38381D 424A4F06 3D4A2EB5 5F76BF48 D57FB957 C05C802B 3161DE03 6895DD8F
  3C7B0203 010001A3 6F306D30 0F060355 1D130101 FF040530 030101FF 301A0603
  551D1104 13301182 0F4F7075 73436F72 65537769 7463682E 301F0603 551D2304
  18301680 14A8F3EF DD632629 CEF9AC20 6F55312E 835646B4 1E301D06 03551D0E
  04160414 A8F3EFDD 632629CE F9AC206F 55312E83 5646B41E 300D0609 2A864886
  F70D0101 04050003 81810069 23FE6240 203BA97E 2A4C605F C434B6CB AB92EC04
  6B16F733 5C37F1E2 C9377165 A1CCA0D6 3A3A26CF 649058D3 EC363701 BDEDF0D7
  DA60BB4D FC7D33D9 DD215AF7 9F9894F3 F102B6F1 1E341F42 B8594211 A44B1EE2
  2A40615A 61457E2D 5BAC0194 FAC6048E 02A816FC B87FC566 904200FC 4C84336A
  EEB468C7 ECC8661D 9380D3
  quit
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
vlan 2-4
interface Port-channel1
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
description OPUS_PBX
switchport access vlan 4
switchport mode access
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
switchport access vlan 2
interface GigabitEthernet1/0/8
switchport access vlan 3
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
description Domain Cont
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree bpduguard enable
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/50
shutdown
channel-protocol pagp
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
description WAP1
interface GigabitEthernet2/0/49
interface GigabitEthernet2/0/50
interface GigabitEthernet2/0/51
interface GigabitEthernet2/0/52
interface Vlan1
ip address 192.168.186.20 255.255.255.0
ip helper-address 192.168.186.17
ip mask-reply
interface Vlan2
ip address 192.168.187.1 255.255.255.0
interface Vlan3
ip address 192.168.188.1 255.255.255.0
interface Vlan4
ip address 192.168.189.1 255.255.255.0
ip default-gateway 192.168.186.1
ip classless
ip default-network 192.168.186.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.186.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password ****************
login
line vty 5 15
login
end
PLEASE if anyone can help me out with this i would appreciate as i do not know what else i can do to get it working.
Thank you very much in advance.
Danila
15 Replies 15
pjmonline
Router needs to know how to route to other subnets. Ip route statements are needed for this. Ip route 192.168.187.0 255.255.255.0 192.168.186.20. Try that and if that does not work please post config of router.
Also note that switch routes traffic to . 1 as its default gateway of last resort.
