ip ospf database-filter equivalent in Nexus OS ?
amit.rai
Is there an equivalent command in Nexus OS for the IOS command " ip ospf database-filter all out"
I want to filter out all LSAs to a neighbor but this command which is available in Cisco IOS does not seem to be available in Nexus OS.
On Cisco IOS
interface Vlan XX
 description TEST
 ip address  A.B.C.D X.X.X.X
Is there any other way in Nexus OS by which i can block all the LSAs to a particular neighbor in same area ?
Reza Sharifi
Appears that this command does not exist in Nexus OS.
It is not available under the vlan interface or routing protocol and I don't see an equivalent for it.
