IPv6 and DHCP labs?
boogeymanperson
Hello, I was wondering if anyone could point me to some examples of using IPv6 with DHCP in a campus environment?  I have looked around the Internet for lab examples on this and have only come up with syntax examples.  I plan on setting up just a small environment, probably only 1 router connected to 1 host just to experiment with dynamic IPv6 address allocation and I was wondering how to do this.  Thank you for your help!
-Dan
Ganesh Hariharan
-Dan
Hi Dan,
Check out the below link hope that helps
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp.html
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
-Dan
Hi Dan,
Ganesh.H
That should work out just fine!  Do you know of any other resources?  I appreciate the help!
