IPV6 compatible?
riderfaiz
Hi everyone,
Hope you can help... My manager asked me to check all our Cisco equipment (including router and switches, , wifi, and ASA we have) to see if they are IPV6 capable....
May I ask what I need to check? OR any special procedures?
Thank you for your help.
Takami Chiro
Reza Sharifi
You will need to use the feature navigator based on the version of IOS and the platform you are using.   Look under "research Software" to figure out if your IOS and platform support IPv6.
http://tools.cisco.com/ITDIT/CFN/
Reza Sharifi
riderfaiz
Thank you very much for your help!
Takami Chiro
