Is it possible to setup a switchport as a passthrough Cisco AnyConnect
netadminstrator
With the sample diagram above:
Red line = Internet Access
Blue Line = Port that setup to use by End user
Light Green  = Ports allocated for VPN
Green Line = Active connection to a remote Cisco AnyConnect VPN Server
Is this do-able?
pieterh
I do not understand your question completely?
but what I think will answer your question is segmenting your network using VLAN's + subnetting
- red: vlan 10 / 10.0.10.0/24 will, for clients then only need internet access
- blue vlan20 / 10.0.20.0/24 separate network for end users
green/light green: vlan 30 / 10.0.30.0/24 vlan to separate VPN clients
this can be done on a manageable L2 switch where you can configure VLAN's
you can keep those networks completely separate
but if you do need traffic between them in the future, you can add a router with AccessList to allow specific trafic
if the switch hat L3 capabilities, this may be done in a single device
if no L3 capabilities you will need to add a router to forward packets between the  vlan's
I want to say, allocate ports from 6-10 to access a pre-loggin VPN that is hosted by Cisco anyconnect at a remote server.
So when a user connects to port 6 of the switch its automatically in the vpn so essentially the ports are pre-configured as vpn.
So i dont need a client, and the switch port will be the client.
