[ISSUE]DHCP Client isn't recieving an ip address with ip helper-address configured
Niels.Postma
Hello people,
I have a problem implementing ip helper-address, my DHCP client isn't recieving an ip address from the DHCP server. I use a Windows Server 2008 as DHCP server.
I've configured a 2811 router as inter vlan router and 2960 switch with a trunk interface to the router, and a access switchport to the 'S-EMINENT01' switch.
I created three subinterfaces (with dot1q encapsulation):
                                             FA0/0.1 (VLAN1, NATIVE) 172.16.0.1/16
                                              FA0/0.10 (VLAN10) 192.168.10.1/24
                                              FA0/0.15(VLAN15) 192.168.15.1/24
Windows Server 2008 DHCP scope:
                                             VLAN10: 192.168.10.1 - 192.168.10.254, excluded range: 192.168.10.1 - 192.168.10.9 /24
                                             VLAN15: 192.168.15.1 - 192.168.15.254, excluded range: 192.168.10.1 - 192.168.10.9 /24
When I configure a static ip address (192.168.10.10) on my DHCP client, I'm able to ping until the FA0/0.1 (172.16.0.1) interface, but I'm still getting no DHCP ip address.
When I configure it within packet tracer, there are no problems at all and the DHCP client recieve the ip address properly. But when I use the same config on physical hardware, it won't work.
Topologie overview:
Note: the S-EMINENT01 is a non-configurable switch.
Config's:
Router:
Current configuration : 1237 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
ip helper-address 172.16.2.10
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.0.1 255.255.0.0
ip access-group 1 in
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.15
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
ip forward-protocol nd
ip http server
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Switch:
Current configuration : 1770 bytes
version 12.2
service config
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 15
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport trunk allowed vlan 1,10,15
switchport mode trunk
spanning-tree portfast trunk
interface Vlan1
ip address dhcp
no ip route-cache
interface Vlan10
no ip address
no ip route-cache
interface Vlan15
no ip address
no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Does anybody have any suggestions or tips? Maybe someone could upload an example configuration for my situation?
6 Replies 6
Antonio Knox
Level 7
Level 7
Is the DHCP server pingable from the physical router?
Yes, the DHCP server is pingable.
Does your interface have:
no ip directed-broadcast
If not, it should.
EDIT: DUH!  I see the config is right here, my bad.  Please add 'no ip directed broadcast' to your interfaces.
Message was edited by: Antonio Knox
Okay, I added 'no ip directed-broadcast' to my physical and all sub -interfaces on my router.
Requested an DHCP ip address on my DHCP client, but still no result.
Have you enabled portfast on the access layer switchport?
spanning-tree portfast enable
And ensured that the host was set to automatically pick up an address (I know, silly question, but I have to ask)?
Can you  get rid of SVIs on the 2960 except VLAN1 but configure this SVI manually then put f0/0.1 in the same subnet as your DHCP server( 172.16.2.0/24 I presume) and exclude this address as well as VLAN1 address from one of your scope.
Regards.
Alain.
