Issue while upgrading WS-4510R+E via ISSU
netops044
I'm trying to upgarde 4510R+E('WS-X45-SUP8-E') via ISSU, while issuing the command (issu loadversion 5 bootflash:cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin
6 slavebootflash:cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin) it's throwing the error as % Active Boot variable is invalid. Please do help me to identify the
root cause for this issue. Here is the IOS image Details & logs for analysis
IOS Image Details & Logs:-
Existing IOS : cat4500es8-universalk9.SPA.03.03.02.XO.151-1.XO2.bin
New IOS : cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin
Switch#$2.E4.bin 6 slavebootflash:cat4500es8-universalk9.SPA.03.06.0$
durd10-01n-sxa02#show redundancy
Redundant System Information :
Available system uptime = 1 day, 12 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 1 day, 10 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.03.02.XO RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 19-Aug-14 02:17 by pr
BOOT = bootflash:cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin,1;
Configuration register = 0x2101 (will be 0x2102 at next reload)
Peer Processor Information :
Standby Location = slot 6
Current Software state = STANDBY HOT
Uptime in current state = 1 day, 9 minutes
Thanks & Regards,
5 Replies 5
Rolf Fischer
Level 9
Level 9
from Configuring the Cisco IOS XE ISSU Process:
Note An ISSU upgrade from any release prior to IOS XE 3.6.0E to 3.6.0E or later is unsupported for IOS XE supervisor engines (SUP7-E, SUP7L-E and SUP8-E).
A permanent “ISSU barrier" exists between pre-IOS XE 3.6.0E and IOS XE 3.6.0 releases:
ISSU is supported between versions on the same side of the barrier but it is not supported between versions on opposite sides.
So in such a case you'll need to perform a manual upgrade. Also have a look at the Release Notes to check if a ROMMON upgrade is required too:
For the Supervisor Engine 8-E to support IOS XE 3.6.0E, the ROMMON version must be upgraded to 15.1(1r)SG4.
Rolf
Hi Rolf,
Thanks for the clarification.
If i do a manual upgrade to 3.6.0E from 03.03.02 will i be able to do ISSU upgrade to the higher versions.
Aside, I could see the existing ROMMAN version as 15.1(1r)SG5 in this case should i need to change the ROMMAN version.
#show v
*Jul 8 14:25:44.803: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisore
durd10-01n-sxa02#show version
Compiled Tue 19-Aug-14 02:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
durd10-01n-sxa02 uptime is 1 day, 25 minutes
Uptime for this control processor is 1 day, 27 minutes
--More--
*Jul 8 14:25:45.828: %SYS-5-CONFIG_I: Configured from console System returned to ROM by power-on
Running default software
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4510R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS2020Q50S
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
1 Virtual Ethernet interface
96 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Thanks & Regards,
Siva Shankar S
Your ROMMON version is more up to date than what is required (15.1(1r)SG4).
Also, once you upgrade to 3.6.0E you should be able to ISSU to higher versions in the same major release, as usually ISSU doesn't work between major releases.   Also, your Configuration register should be 0x2102.
Thanks Reza.
Thanks Reza I could able do ISSU without any issue.
