It does not save the configuration SW C9300L-48P-4X
We are experiencing an issue with a Cisco Catalyst C9300L-48P-4X where the device does not save the configuration. After running commands such as:
Version:17.12.2r
write memory copy running-config startup-config
the configuration is not stored and is lost after a reload.
Could you please assist us in identifying the root cause?
Below are the details and information we can provide or collect if needed:
  • Platform: C9300L-48P-4X
  • Running mode (Install/Bundle)
  • NVRAM status and free space
  • Flash/NVRAM filesystem status (possible read-only condition)
  • Stack status (if applicable)
Please let us know what additional logs or outputs you require to troubleshoot this issue.
Thank you,
Regards.
Mark Elsen
  - @Francisco Leon     Check this document, and verify your settings :
                                                   https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Please post the complete output to the following command:
sh romvar
