Kron issue
stephen.stack
Level 4
Level 4
While carrying out some troubleshooting on a GRE tunnel, i wnat the KRON command to carry out a ping to the remote site once a minute. However when the command executes, the kron policy list deletes from the config. Hence it will not run any more.
Here is the Kron config
kron occurrance PING in 1 reccurring
policy-list PING_POLICY
kron policy-list PING_POLICY
cli ping 192.168.0.254
Any ideas as to how to keep the policy list there so that the ping will run every minute.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
a-vazquez
Level 6
Level 6
check out the following link for scheduling a kron command recurringly, hope this helps :
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_feature_guide09186a00801b0695.html
