L2 Extension - Using CSR 1000v
sagilshravana
I wanted to create a DCI between two Datacenters (DC1 &DC2) and extend the LAN over WAN/L3.   DC1 use traditional VLAN and DC2 uses VXLAN in their respective LAN.
I found a cisco document explaining solution for  a similar case but in that case it was using VLAN at both the ends. https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/vxlan/m_csr-vxlan-support-book.html
Can someone please help ?
0 Replies 0
