LAN - Auto QoS
Is it a good idea to run Auto QoS on the LAN switches (Cat 4500s/6500s - IOS), even if the call manager cluster is located across the WAN? Does it matter where the CUCM cluster physically resides when considering deployment of Auto QoS? I currently have QoS enabled on the WAN routers. I want to prioritize VoIP/Video traffic and ensure that my local network management, routing protocols, etc..are still accounted for in the event of heavy congestion. Is this the model to use? Thanks in advance.
vvasisth
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/auto_qos.html
This link will give you everything you want to know with regards to auto QOS.
regards,
Varun
