LAN Design Query
ahmad82pkn
Level 3
Level 3
This might be a bad question, but i was just hoping to get some best option to work on.
in diagram attach you can see existing office in white and my new office in YELLOW color.
I have connected new YELLOW Office 2 core switches with existing 2 core switches on office 1.
New office will use existing bandwidth of current office.
my question is what is best way to connect both office CORE switches for 100% redundancy in case of link failure between core switches.
one option that come in my mind is make a layer 3 VLAN between all 4 core switches and run HSRP between them lets say
Vlan 192
Office 1 Core 1 IP = 192.168.1.2
Office 1 Core 2 IP = 192.168.1.3
Office 1 HSRP IP = 192.168.1.1
Then
Yellow Office Core1 IP = 192.168.1.4
Yellow Office Core2 IP = 192.168.1.5
Yellow Office HSRP IP = 192.168.1.6
And then do routing on HSRP Gateway IP.
is it right way to go?
and what other options i have?
thanx in advance
Reza Sharifi
Between you 4 core routers you can simply use a routing protocol and that will provide redundency for you..
Run HSRP for your vlans and connect 4 core devices fully meshes. Use /30 (routed) for each segment.
Core 1 to to core 2 IP = 192.168.1.0/30
Core 1 to to core 3 IP = 192.168.1.4/30
Core 2 to to core 1 IP = 192.168.1.8/30
Core 2 to to core 3 IP = 192.168.1.12/30
Use OSPF for all your segments including the vlans.
