On the AP's themselves, you can configure a Primary, Secondary and Tertiary Controller.
Say for example you had 20 Access Points and you wanted to load balance 10 on each controller.
You would make the Primary Controller on the first 10 AP's be Controller 1 and the Secondary Controller be Controller 2.
Then you do the reverse on the second 10 AP's.
Hopefully that makes sense!
