Loopback question
lhorton311
Community Member
So I have a two router network. On one router i have a few 10.1.x.0 loopbacks. The connection between the routers is fa 0/0 using 192.168.10.1 /28 and 192.168.10.2/28. The 192.168.10.2 has the loopbacks on it. When I try and ping 192.168.10.1 from the loopback using extend ping they time out, but when I ping the 192.168.10.2 on the same router it succeeds. I cannot get accross to the other router. What am I missing? Any help would be appreciated.
Reza Sharifi
You need to install route from that router to reach the loopback address of the other one
example
ip route 192.168.10.1 255.255.255.255 192.168.10.1
