MIB name for switch IP and local clock
ajwhite0
I need to use the correct MIB and OID name to get the switches IP address and also what it's local time is, is this possible?
For the IP I did find this, but is depreciated:
1.3.6.1.2.1.4.20.1.1 (ipAdEntAddr)
Can't find anything for local time.
5 Replies 5
Mark Elsen
  - FYI : https://community.cisco.com/t5/other-network-architecture-subjects/how-to-get-show-clock-information-by-snmp/m-p/102802/highlight/true#M34257
    Or you may try : https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.131.1.1.1
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Uptime I already have, looks like you can't do 'show clock'
Do you know what MIB this is part of?
  - FYI : https://mibs.observium.org/mib/IP-MIB/
             (IP-MIB)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
does it matter if it's depreciated?
 - Depends , check if the OID is usable on the intended target switch,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
