mls qos enabled globally and disabled for only one interface
dmaillard91
Hello !
My switch is Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX5, RELEASE SOFTWARE (fc1)
I try to disabled mls qos only for one interface, but when i do it, mls qos is globally disabled. Is it possible to do it ?
XXX#show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
XXX#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
XXX(config)#interface gigabitEthernet 1/0/5
XXX(config-if)#no mls qos
XXX(config)#exit
XXX#
XXX#show mls qos
QoS is disabled
Thanks in advance for your help !!
Denis
InayathUlla Sharieff
Hi Denis,
You cant disable the QOS on per interface on 2960 devices.
By default, QoS is disabled. When we enable QoS all ports
will be assigned to queue-set 1. We can configure up to two
different queue-sets.
Hence if you remove the qos out of the interface it would be disabled globally as well.
Hi Denis,
Were in following things mentioned in the below document can be disabled individually on the port.
http://3c3cc.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/consolidated_guide/configuration_guide/b_1522e_consolidated_2960x_cg.pdf
Do a search for " no mls qos " you will get more options here.
