Multicast Process High CPU utilization
sungard.apac
Frequent Visitor
Frequent Visitor
Hello ,
I am seeing high cpu process utilization by multicast process. Any one has idea if it is some bug ?
#show processes cpu sorted
CPU utilization for five seconds: 69%/41%; one minute: 69%; five minutes: 68%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 256    16887156    12340568       1368  8.87%  8.61%  8.70%   0 MRIB Trans
 126     8863140    22803268        388  6.87%  6.66%  6.63%   0 IP Input
 265    12063212     8946629       1348  5.27%  5.20%  5.27%   0 MFIB_mrib_read
 264     4798708     8814607        544  2.79%  2.66%  2.67%   0 MFIB_mrib_write
version 15.1
Type             : CISCO2911/K9
Georg Pauwen
this is the only bug I could find, check if that applies:
Memory leak at mrib_mesg_alloc()
CSCua04865
Description
Symptom:
Memory leak observed in two processes namely 'MFIB_mrib_read' and 'MRIB Trans'. System memory will go down gradually eventually leading to a router crash due to lack of memory. 'show proc mem sorted' will point to the above two processes consuming steadily increasing memory.
Conditions:
When ip multicast bidir config is used.
["ip pim bidir-enable"]
Workaround:
Once low memory condition is seen, no work-around exists except to reload the router.
But if system has memory available, further leak may be prevented by disabling ipmulticast bidir configuration. This can be done as:
conf t
no ip pim bidir-enable
Issue can be avoided by not running bidir (using the above config to disable bidir)
